New to setting up fuel injection
Old May 17, 2012 | 10:05 PM
thenovaproject's Avatar
Default New to setting up fuel injection
Setting up regulator
Got the red Aeromotive one
What's the chrome long nipple thing used for.
Please help
Thank you in advance
Brian Stankowitz
Old May 18, 2012 | 10:05 AM
onefastrx7turbo's Avatar
sounds like the boost reference nipple. only need it if you are forced inducted. leave it open if not
Old May 18, 2012 | 01:35 PM
Thanks
What does it do if I am running turbos ?
Old May 18, 2012 | 02:49 PM
ZL1Killa's Avatar
it raises the fuel pressure to compensate for the amount of boost you are running. reason for this is your actual injected fuel pressure, if normally 58psi, if you are running 10psi of boost, your actual injector fuel pressure is 48psi; and at that pressure you have to ensure your fuel injectors flow enough to keep up with your setup.
for every pound of boost you increase, the regulator also increases to maintain the equivalent same fuel pressure
