Fuel plumbing path to engine bay help needed
Old Jun 24, 2012 | 11:27 PM
TexasVortexx's Avatar
Arrow Fuel plumbing path to engine bay help needed
My original fuel line path brought it up the passenger frame beneath the hvac box and very close to the header where it Y'd off into both the injector and nitrous fuel systems (see attached). I'm considering bringing the line along the frame to the k-member and on into the path beneath where the original battery sat behind the passenger headlight and on to the regulators nearby. Where do you have yours routed?
Old Jul 4, 2012 | 12:22 PM
ZeeTwentyFate's Avatar
i know its late but mine ollow the stock path, then up in the fender well and i hole saw'd a hole beside the brake master cyl, lined it with vacuum hose to keep it from cutting the lines and put my regulator where the t56 master cylinder reservoir sits.
Old Jul 6, 2012 | 04:53 PM
Tirefire's Avatar
I did the same I followed the path of the factory lines and break lines. I used lowes 1/2 inch hangers and zip locks. Looks pretty good, I even used the factory aluminum shielding. Then I went through the back of the break booster and across onto my fuel rail.
