255lph on stock motor?
Old Jun 26, 2012 | 06:11 PM
usmonaro's Avatar
Default 255lph on stock motor?
I have a 2000 Z28 A4 with only an SLP lid. I am planning on upgrading several things in the future and have purchased a 255lph pump to replace my stock one that has went out. Is there going to be any issues or am I going to have to regulate it down any. From the way I understood its like a reserve, that all the fuel will bypass back through the return line into the tank anyways. Would appreciate some knowledge on this subject.
Old Jun 26, 2012 | 07:05 PM
salemetro's Avatar
Correct.
Old Jun 26, 2012 | 07:37 PM
ZL1Killa's Avatar
you are correct. Having the larger pump does not have any ill effects. Your stock regulator will take care of this also.
make sure you purchased the wiring harness with it... you will wish you had if you didn't. If you didn't, just get some good heavy gauge wiring (fused) properly for the pump and sized properly for the amperage of the pump.
Old Jun 27, 2012 | 12:04 PM
superGTO's Avatar
Better to have more fuel than not enough.
Old Jun 27, 2012 | 04:27 PM
usmonaro's Avatar
Cool. I'm now only worried about cutting the stock fuel pump bowl. But I'm sure ill make it work somehow.
Old Jun 27, 2012 | 06:09 PM
Zbinkley's Avatar
Did you buy the racetronix pump? If not, I'd send the one you bought back and get the racetronix. It fits in the stock location and the harness is plug and play.
Just my $.02
