double pump/hobbs switch ?
It seems like most people are setting the hobbs switch at 1psi so the second pump activates with any boost pressure, but is a hobbs switch needed?
Is there any reason not to run both pump all the time?
Car is a 02 so it uses a return, what problems would arise from just running both pumps as if there was only 1
reason NOT to run both pumps at the same time, because theres no need for added constant electrical load when its not needed.
with the 2 pumps running all the time, they will heat up the fuel, you dont want that.
and it will wear the pump out faster.
im sure other guys have other reasons as well...
