Confused with non returnless
If you start the car and the fuel pressure goes way up at idle, it's likely the stock regulator causing the issue. Due to the cost of running a full return-by-the-rails regulator, I'd make sure it was an issue that couldn't be dealt with some other way, like through tuning.
