Wiring External Fuel pump Questions...
I know the 2 purple wires on the inside go to the the sender for fuel level and the white and black wires are power and ground to the old stock pump.... but when they go into the bulkhead they change colors...
So my question is does anyone know wich wires i can use out of the stock harness to run my external pump?.... these are the colors
Purple..
Solid black...
Gray...
Black with white strip....
Can i cut the black and white wires out of the tank sinse there going to do nothing but sit in the tank and does the stock ground have to stay attached?
Am i going to have to run a new power, and accessories?? Who else has done this??
One more question... of the 4 tubes coming out of the tank only 2 are still used correct....? the stock breather wich is this one closest in this pic and the stock feed correct?
So the other 2 i just block off and im done... any pics would be greatly appriciated.
Thanks
Kyle
but you need a feed (your sump), return (sump or top?), then breather, any others you should be able to block offf
for the power wires why not use a multi meter to make sure.
id leave the ground, if grounded to tank to avoid sparks or something.
anyone????
Thanks
Kyle
1. FEED out of Sump
2. Stock feedline as return nocked down to only one line with other blocked off
3. and breather for the tank
Is that right??
Thanks
Kyle
