Fuel system upgrade
Old Apr 6, 2004 | 04:21 PM
mike02ss's Avatar
Default Fuel system upgrade
What are you guys using for fuel upgrade on the plastic tanks? I have an 02, does an inline pump do any good or is it better to have an intank pump put in. I want a fuel system that can support 550-600rwhp. Thanks. Also what pump would you recommend.
Old Apr 7, 2004 | 12:28 AM
Nasty N8's Avatar
An inline barely helps you you can not pull any more fuel through the pump in the tank. Do a intank Walbro 340m hotwire it to the alt. and maybe upgrade the fuel rails. Should be good for about 600-650rwhp
Nate
Old Apr 7, 2004 | 06:15 AM
smokinHawk's Avatar
a walbro 340 intank (hot wired), with stock rails and 42lb svo's should support 600rwhp
anything more, you'll need another pump, or bigger, bigger lines and rails.
