Has anyone that has done the access door regretted it?
Old Apr 7, 2004 | 07:52 PM
bill99hawk's Avatar
Default Has anyone that has done the access door regretted it?
I am very tempted to do the access door to fuel pump mod, but I am still contempt on doing it. Anyone regret this decision or not?
Old Apr 7, 2004 | 08:45 PM
frcefed98's Avatar
I regret not doing it earlier. Between today and yesterday I had my pump out 3 times trouble shooting a problem. If I had to drop the tank everytime I had to do this I would have shot the car lol. It made it real easy when I stepped up to doing the racetronix set up too. 1 vote for doing it here.
If you have a an issue with resale value latter on, don't tell them there is access panel back there, what they don't know won't hurt them....
J
Old Apr 7, 2004 | 08:49 PM
andy98Z's Avatar
Yea...I made the mistake of droping the tank to do the pump, put it back up had a problem then dropped the tank again...had another problem, finally said f it and cut the door, so easy now ....I dont regret it, especially if u make sure it doesnt rattle.
Old Apr 7, 2004 | 10:33 PM
PongoX11's Avatar
Nice to see, after remembering how well the exhaust shop re-aligned and "super" secured my catback after I installed my headers--I dont even want to know how long it will take to remove the catback.
I have now decided I am going to cut for sure! Anyone have exact measurments on a '99, think its the same 99-02.
Old Apr 7, 2004 | 11:06 PM
Mike K.'s Avatar
Its really not that bad, You can do the whole thing including fabbing the fuel bucket with a dremel. Plus chances are you will one day have to go back in to mess with the fuel pump/system again so you may as well cut the hole. Nobody will ever know
Old Apr 8, 2004 | 03:41 PM
Black LS1 T/A's Avatar
Moderator
I'm SO glad I cut mine. The only people I've heard regret it are those who have not done it.
Old Apr 9, 2004 | 03:35 PM
GM Muscle's Avatar
Basicly you need to cut an 8"x8" square starting at the radiused part of the trunk. That will give you plenty of room to get everything out. Just becareful cutting, the lines and wiring harness' aren't to far under the steel. Here's a pic of mine.
Old Apr 10, 2004 | 07:31 PM
2FAST4U's Avatar
I have a the MOROSO Easy access door mounted in my car and I will reinstall the carpet under the door. So when you look you see the door, one quick dzus fastener and there is the pump hole. But no pump, I have external. Sorry no pics of it installed yet!
Attached Thumbnails Has anyone that has done the access door regretted it?-71085700.jpg
Old Apr 10, 2004 | 08:09 PM
bill99hawk's Avatar
That is really cool! Where and how much?
EDIT: Found it at Jegs and Summit, but is the access door large enough to work with? The specs are 8-1/8'' square frame, 6'' square door.
Old Apr 11, 2004 | 09:29 AM
SPANKY LS1's Avatar
How far is it between the steel and the nearest component that can be damaged (wires, lines, etc) when cutting? 1", 2"? What did you cut yours with, dremel or some kind of saw?
Thanks, Shawn
Old Apr 11, 2004 | 10:02 AM
GM Muscle's Avatar
A dremel with a reenforced fiberglass cutting wheel works great. The wires are actually closer to the metal than the lines. I'm guessing at what it was but the wires were probrably 1/4" or so and the lines were atleast a half an inch.
Old Apr 11, 2004 | 11:18 AM
Dutch SS's Avatar
Thanks, Shawn
on mine it was only about 3/5 of an inck.....have to be VERY careful. I used a cutoff wheel, and still mananged to "nick" one of the quick release fuel line fasteners.......
Old Apr 12, 2004 | 12:10 AM
2FAST4U's Avatar
Well if I had to I could just remove the dor to work there not a big deal. But as I said I don't even have a pump there now! Pump Is a weldon external. The door is for access to some wires,fuel lines,and sending unit.
Old Apr 12, 2004 | 02:36 AM
Flamin Raven's Avatar
The time the access door saves is well worth it. Who cares about the hole in the car its covered by the carpet anyway. Save yourself the time and effort of dropping the tank and cut away. You won't regret it!
Old Apr 12, 2004 | 11:47 AM
NicD's Avatar
7 Second Club
Very easy, absolutely no regrets.
Writeup link on my website in the performance section under the fuel pump image.
Old Apr 13, 2004 | 04:46 PM
MECHAM's Avatar
no regrets...best free mod i have ever done
like someone posted above...just make sure you tape the lid back down or else it will rattle...but other than that...yr all good.
Old Apr 13, 2004 | 10:28 PM
Brains's Avatar
Just did mine tonight -- no regrets at all cutting the hole... Instead of using a cutoff wheel and making a big mess, I spent six bucks at Harbor Freight and used this instead:
http://www.harborfreight.com/cpi/cta...itemnumber=539
Talk about making that little task EASY !!! Drilled two holes at the corners, and started cutting. I left the flap attached (cut only three sides), and just bent it forward to expose the pump, then folded it back down when I was done. I'm going to fab up a nice cover over the hole eventually, but this was quick and easy. The hole took literally 2 minutes TOPS to cut, and the edges are nice and straight.
Old Apr 13, 2004 | 11:05 PM
Mike K.'s Avatar
Pretty cool tool there, I dub it the the LS1 fuel pump access hole cutter!!!
Old Apr 14, 2004 | 11:19 AM
Chris99WS6PWTMET's Avatar
Good find Brains!! That is the tool I have been using and talking about on here for the past year but I could never find a pic of it.
That link should make it much easier for folks to do this mod now and not mess anything up.
Kick ***!!
Old Apr 14, 2004 | 01:57 PM
bill99hawk's Avatar
Kick ***!!
Cool I have a local Haborfreight store I can pick on up at and will do the cut this weekend.
