Barry Grant fuel pumps
Old Apr 9, 2004 | 04:03 AM
11 Bravo's Avatar
Default Barry Grant fuel pumps
I can get a good deal on a Barry Grant 280gph pump. It is supposed to be good up to 650hp. I need a system for a n/a 427. Yea or nay?
Old Apr 9, 2004 | 11:40 AM
Nasty N8's Avatar
280GPH is way more than 650hp at the LS1 pressure what model is it and is it for injection? sounds like a carb pump.
Nate
Old Apr 9, 2004 | 12:26 PM
11 Bravo's Avatar
I believe it is the BG280. Is it for carbs? I think this link has it:
http://www.racenet.net/fuel/barry-grant-pumps.php
Old Apr 9, 2004 | 12:50 PM
BTL FED's Avatar
Yes that is a Low Pressure Pump ment for carb engines, if you look in the details about it, it mentions 18 psi, ls1's need around 60 psi
Old Apr 9, 2004 | 07:25 PM
11 Bravo's Avatar
Thanks guys. I wasn't sure.
Old Apr 12, 2004 | 12:52 PM
Nasty N8's Avatar
Yep you need a high pressure pump. Shoot me an E-mail I can set you up with the fuel system you need.
Nate
By Brett Foote | 2026-06-04 05:00:17
