Broken fuel injectors!?!? PIC INSIDE
Old Oct 10, 2012 | 03:47 PM
k_cash1432's Avatar
Default Broken fuel injectors!?!? PIC INSIDE
So i recently purchased a set of fuel rails and injectors from a member and he said he took them directly off of his vehicle and had no trouble with them. Upon reecieving them i noticed they were missing a few orings~ no problem i would get some new ones anyways. Upon further inspection i noticed the clip on the bottom of the injector was missing, not only is it missing on one but it is either missing or broken on all 8 of the injectors! Please take a look at the pic and tell me if i can use the injectors or if i need to get some money back. THanks
<a href="http://s760.photobucket.com/albums/xx242/k_cash1432/?action=view&amp;current=photobucket-34544-1349901758547.jpg" target="_blank"><img src="http://i760.photobucket.com/albums/xx242/k_cash1432/photobucket-34544-1349901758547.jpg" border="0" alt="2012-10-10_14-09-42_733"></a>
Old Oct 10, 2012 | 08:53 PM
99Bluz28's Avatar
With new O-rings you should be able to use the injectors, but the seller should have informed you about the condition of the injectors, and since they're all are like that I wouldn't want to attempt to run them if the way they were handled or stored looks obviously questionable.
I'd request a partial refund.
Old Oct 10, 2012 | 08:59 PM
k_cash1432's Avatar
What is that little clip that is on the end of the injector Thats what im more conserned about. On the lower injcetor it is broken in half and on the upper one it is MIA! what is it, a retainer clip for the o-ring?
Old Oct 11, 2012 | 02:09 PM
Old Geezer's Avatar
O'ring retainer.
How long have the injs been out of the car? If an extended time, they may be gummed up and won't perform correctly.
Have them cleaned and flow tested. Part of the cleaning is replacement of the wear items, including the rings and retainers.
Old Oct 11, 2012 | 03:31 PM
k_cash1432's Avatar
They guy said he just pulled them off of his car and sent them directly to me. Does it seam fishy to anybody else?
Old Oct 13, 2012 | 01:32 AM
Albertan's Avatar
I have used Mr. injector for injector parts including the screens.
http://www.mrinjectorparts.com I would always use new parts when installing injectors. Parts are really cheap.
Old Oct 13, 2012 | 09:07 PM
k_cash1432's Avatar
So looking at mr injector i think it will run me about 30 for the parts to replace what i need. Should i ask for that in a refund?
