1500fwhp E85 Fuel System ???????
Old Oct 24, 2012 | 06:35 PM
Anchor's Avatar
Default 1500fwhp E85 Fuel System ???????
Sup guys, i've done a lot of searching and surfing the net for answers. Hopefully i'll get some good ones here.
Boosted 398ci LS. Max 18-20psi. Heads will start to lift at around 1400fwhp.
Street car. Will see 8 hours of highway use and a full week at a circuit then 8 hours highway home. Also be driven to work etc.
I'm at a loss to my fuel system, i want to over engineer it so i'm not replacing and upgrading if i want to push the limit of my bottom end on E85.
Fuel pumps - in tank, in line or belt drive? Which ones will flow what i want?
Feed and return size? Hard line or braided?
What reg and filter? I have an FPR1200?
Won't be using stock tank either. Looking for around a 20gal fuel cell with intank pump. Kept coming back to the Aeromotive Eliminator setup. If only they offered it with a Pro Series pump.
What size/brand fuel injectors? I have the fuel rails that come with the holley hi ram inlet.
Will be running pump gas to start with. If i can't make the power on pump (98 octane here in Aus) i'll switch to E85. Don't think i want to use water/meth.
Thanks for the help
Jeremy
Old Oct 25, 2012 | 12:43 AM
Blown06's Avatar
8 Second Truck Club
1500 rwhp and e85..............belt drive will be the only way I'd think
Old Oct 26, 2012 | 02:11 AM
Anchor's Avatar
1500 fly. Not rear wheel. I think belt might be the way to go. But are they streetable? I don't want a pump with a half hour run time and cooked fuel..
Old Oct 27, 2012 | 01:36 AM
Blown06's Avatar
8 Second Truck Club
belt driven pumps don't heat the fuel like an electric pump
Old Oct 27, 2012 | 02:49 PM
jasond26's Avatar
I run a belt drive on the street, I will never go back to electric. No current draw and no hot fuel......best part, no fuel pressure drop
Old Oct 28, 2012 | 03:16 AM
Anchor's Avatar
Ok i'm not gunna have much room for a belt drive with AC & PS. I don't think anyway..
The cam drive ones, i'd have to use a cable and remote mount it because of my waterpump?
Would prefer belt. But yeah unsure on room.
