Fuel problem
Old Nov 9, 2012 | 11:47 PM
gwizz15's Avatar
Default Fuel problem
Just installed cam and trying to do a dry run with out radiator hooked up anyways after try to start it for 20 min or so have spark and fuel in fuel rails then I check a spark plug and it was dry.
Fuel injectors???
They were only sitting for 1 day can't see how they could go bad already.
Old Nov 10, 2012 | 07:54 AM
Old Geezer's Avatar
Noid the injs and see if they are firing.. Likely not.
Fuse? Everything plugged in? All grounds hooked up?
Tach signal?
