Injector help!
Old Nov 25, 2012 | 10:43 PM
Jarren_b's Avatar
Default Injector help!
Hey guys so Im planning a cam swap and im almost ready.. last thing I need are some injectors ive been told.
Ive found some cheap ls2 injectors for 50 bucks and im wondering, 1. are they worth it for that price?
2. what all would I need to make an LS2 injector work on my LS1?
3. is their an easier or better alternative?
Ive been reading and it seems to make it work I need spacers and connector adapters. is this true?
How can I make this easier?
Can I run my stock injectors still? (im swapping to the TSP torquer V2)
Any help is greatly appreciated
Old Nov 26, 2012 | 02:52 AM
2000PewterT/A's Avatar
If money is tight you can get away with running stock injectors with a good tune, but I always like to upgrade my injectors just to be safe. There are plenty of routes you can go, some guys run aftermarket injectors, and I have seen some guys run the white top injectors (IIRC) from the GTP/Regals. I believe they are 40 pounders but don't quote me on that. There are also sponsors on here that will take your injectors and resize them to flow whatever you want.
Old Nov 26, 2012 | 11:08 AM
ZL1Killa's Avatar
give FIC Injectors a call. Fuel Injector Connection
Old Nov 26, 2012 | 01:17 PM
Jarren_b's Avatar
Well ive decided to go with the ls2 injectors and I bought the adapters for the connector but do you guys know if It requires anything else to make it work? o-rings? spacers? ect..?
