Issue with fuel pump
Old Dec 14, 2012 | 04:02 PM
rggbly's Avatar
Default Issue with fuel pump
So on my way home for christmas break my trans am died when pulling into a gas station and would not start back up. The fuel pump does not prime when turning the key. I have tested the relay and it is working properly. The problem is that I'm getting voltage at the relay box under the hood but I'm not getting any voltage from the wires at the fuel pump (I cut the trap door). I'm getting a 5v reading from the pink wire when the key is in the on position. At this point I'm beginning to wonder if it's an electrical problem between the fuse box and the fuel pump and not the actual fuel pump. Does anyone have any knowledgable input on where I should go or what's going on?
