Boosted LS fuel system configuration
Old Jan 5, 2013 | 02:02 AM
HexT's Avatar
Default Boosted LS fuel system configuration
Please let me know if I'm overlooking something. This is a 408/88mm/E85 combo, trying to get the fuel system right in my head. Pump is a Magnafuel 4303 (I know this will probably be maxed out) and FIC2000's. Stock truck ECU for now with Holley EFI in the future.
I made this diagram to make sense of it to myself, will this work alright?
From what I understand the external FPR will set the base pressure (43.5psi w/3bar MAP) and I'll pull vacuum before the throttle body on the intake pipe for boost referencing, right?
Old Jan 5, 2013 | 09:43 AM
SSInnovations's Avatar
I'm pretty sure you need to source the vacuum after the TB for the FPR; I am setting something similar up and am using a port on the intake. When the throttle closes the spike in psi pre-throttle body will hike your fuel pressure when it should be falling off.
Old Jan 5, 2013 | 10:06 AM
LS1NOVA's Avatar
Boost reference after tb. Looks like you have it nailed down.
I did 997whp on a friends car through an unlocked 4L80E with the same 4303 pump and setup.
Old Jan 5, 2013 | 11:56 AM
HexT's Avatar
Sounds good guys, thanks for clearing that up.
