fuel pump interchangeability??????
Old Jan 5, 2013 | 08:35 PM
onefastsunsetSS's Avatar
Default fuel pump interchangeability??????
i was wondering if the fuel pump motor from an lt1 will work in my 02 ls1 camaro? i 'm sure i will have to swap the motor itself out and use my sendin unit, but as long as i use my regulator and the pump fits i figure i could even use a pump motor from a 6 cylinder f body. i tried a couple search on stock pump interchanges but found nothing so far.
Old Jan 6, 2013 | 09:18 AM
Lonnies Performance's Avatar
LS1TECH Sponsor
You can make anything work with enough effort, but there are 4 distinct pumps
LT1, 98 f-body, 99-02 V6 & 99-02 V8. Buy the correct parts & save yourself some grief.
Old Jan 6, 2013 | 06:06 PM
my issue is right know i may be dealing with a car with a cracked block plus????
long story, but my car has been sitting for 5 years and i just put a bunch of money in it and would like to go to the junkyard, get a fuel pump motor to put in my sending unit, and see if the car starts. and runs for awhile.
i have nowhere to keep the car anymore. i fixed the stuff that sidelined it for years. if it needs a new motor i'm forced to sell it.
can anyone tell me what motor may fit in a 99-02 sending unit?
thanks for your time
Old Jan 6, 2013 | 08:58 PM
LS1TECH Sponsor
Call me, I can set you up with a new factory pump (with fuel sock & hose) for $69.
Old Jan 7, 2013 | 06:19 AM
wkdivr's Avatar
Take Lonnie's suggestion. Don't use a pump from the junkyard.
