Hot wire kit
Old Jan 20, 2013 | 02:13 PM
tmoney223's Avatar
Default Hot wire kit
I'm doing a duel walbro set up and was wondering if I can use 1 hot wire kit for both, or do I have to use 2 hot wire kits?
Old Jan 20, 2013 | 04:51 PM
NOS LS1's Avatar
You can not use 1 hot wire kit for both pumps. This will over load your fuel pump electrical circuit.
You should contact Lonnie's Performance. Lonnie is a Sponser here on LS1 tech .
He is very knowledgable on fuel systems.
Lonnie has a Heavy duty wiring harness for running dual walbro fuel pumps. He offers complete kits that include dual fuel pumps.
Lonnie will modify your fuel pump bucket assembly for dual pumps if you send yours to him.
After he does this...You can just drop in the new Dual walbro pump assembly.
Lonnie told me that the secondary walbro fuel pump is only activated when switching your nitrous arming switch to ON.
When you shut OFF your arming switch... you go back to operating on the primary pump only.
Heres the Link...
http://www.lonniesperformance.com/
Old Jan 20, 2013 | 08:16 PM
tmoney223's Avatar
Ok thanks!
Old Feb 3, 2013 | 09:56 AM
bigbrdf250's Avatar
Heres the Link...
as far as only using one hot wire kit???
in my case i have a drag car only and is only on for moments at a time so its not like im driving the streets for long times and sitting at lights.
will i be ok just using the one hotwire kit??
