Delphi fuel injector question. Need help
Old Jan 27, 2013 | 06:37 PM
quik2dr's Avatar
Default Delphi fuel injector question. Need help
I recently purchased a used 92mm fast intake from a guy that had the stock fuel rails and delpi 42lbs injectors still with it. (part number 01D030B)Im getting ready to run this on my 2004 gto. From looking at other injectors, this is fatter insize compared to the slim ones. Will this make a difference? Will these even work with the wiring harness on my gto? I was also looking at purchasing the Fast Ls1 fuel rails. Just wondering if they will work with it also or if im gonna have to ditch them for a newer set of injectors? Sorry for asking noob questions but im not really a techincal gear head. Im just good at changing parts
Old Jan 27, 2013 | 07:37 PM
FICINJECTORS's Avatar
It will all drop in your ls1.. They are not Delphi, they are SMP 42@3 bar. So they will be 50 at ls1 pressure.
Old Jan 27, 2013 | 09:20 PM
quik2dr's Avatar
Will this be overkill for my car? My current mods are longtube headers, catless midpipes, catback, big cam (.238/.240 .607/.609) k&n intake. My mods going on are a fast 92/92 setup and a set of stock 243 heads. When you say 50 at ls1 pressure that is using the stock fuel rails?
Old Jan 27, 2013 | 09:40 PM
You only need 32 @3 bar which flow 36@ 58. Also since there is no tune data for those smp injectors, without a real good tuner you will probably be real dirty at the bottom end. yes to your question
Old Jan 28, 2013 | 06:01 AM
quik2dr's Avatar
Thanks for all your time and help. I posted the same question on the gto forums and only got smartass comments. Ill start shopping around for a new set of injectors unless you know off the top of your head what will be good
Old Jan 28, 2013 | 06:06 AM
quik2dr's Avatar
would a set of your 36lb blue demon injectors be good? Im not wanting to cut corners but also trying to stay within a budget
