Need any special tools to replace fuel pump?
Old Mar 6, 2013 | 02:01 PM
RebelExtrm02's Avatar
Default Need any special tools to replace fuel pump?
I'm going to dropping my tank and replacing my fuel pump with a racetronix unit this weekend. Are there any special fitting tools or the like needed to disconnect the lines and remove the pump? I'll be a bit isolated where I'm doing it so I want have everything I need ahead of time.
Old Mar 6, 2013 | 07:31 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Perhaps you should join our support forum and look at the GM docs that cover the re & re?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 7, 2013 | 02:53 PM
I have joined the support forum but cannot find the aforementioned docs. Can you link me to them?
Old Mar 7, 2013 | 06:19 PM
Racetronix's Avatar
LS1TECH Sponsor
Did you verify your e-mail account as required by all forums? We do not see any pending authorizations.
__________________
>WEB SITE<
Old Mar 7, 2013 | 06:51 PM
Yes, I can get on the forum just fine. The only documents i've found in any of the sub forums though is the instructions you sent with the pump. I can't find any other gm documents.
Old Mar 7, 2013 | 10:38 PM
Racetronix's Avatar
LS1TECH Sponsor
Then you did not look at the stickies for the F99 section.
FPA-001 (F99-FPA) Fuel Pump Assembly Diagnostic Procedures
__________________
>WEB SITE<
