ls6 repair
Old Mar 26, 2013 | 09:57 PM
superstreeter's Avatar
Default ls6 repair
I need some ideas or products to repair a LS6 intake composite,I just happened to grind through the corner, when trying to clearance it for steam tubes underneath. Im building boost too, so what ever I use has to handle pressure !!
Old Mar 26, 2013 | 10:00 PM
sabastian458's Avatar
JB weld. It's still hold my old 3000GT's trans together with the new owner 100,000 miles later.
Old Mar 26, 2013 | 10:04 PM
Thanx for the tip, but an aluminum trans is a bit different than a composite intake.............not sure if jb weld works on plastic ???
Old Mar 26, 2013 | 11:07 PM
egod's Avatar
Check these guys out, they look they have a few solutions for you.
http://www.cyberbond1.com/adhesive-s...adhesives.aspx
Old Mar 29, 2013 | 10:27 PM
5.3Notch's Avatar
I would try to find a local plastic welding shop, Those LS6 intakes dont grow on trees you know.
