help with fuel pump issue.
Old May 5, 2013 | 04:21 PM
omarrakeen's Avatar
Default help with fuel pump issue.
long story short I just finished installing a new TRE performance fuel pump. i did the trap door and did it my self. drove fine for a day then it stopped working, the pin connector was loose (my bad) fixed it and it worked like a charm. drove another 300km and suddenly it stopped today!! guage was pointing at 1/4 it felt like it ran out of fuel. i added fuel A LOT of fuel and its still doing the same thing!! it sputters and misfires like it has low fuel. all connectors seem fine. what do i look for? i took the pump out twice, am ready to lit the car on fire now
do i tow her to a garage? or take the pump out again in the middle of the street? i dont have a pressure guage. could it be one of the lines? or vaccum? ideas please!! thank you.
Old May 5, 2013 | 07:36 PM
Ollie8974's Avatar
Check this link, Post #18.
https://ls1tech.com/forums/fueling-i...-drop-wot.html
Old May 5, 2013 | 11:27 PM
omarrakeen's Avatar
Originally Posted by Ollie8974
thanks for the feedback. are you suggesting an in tank regulator? or in tank leak?
EDIT: am taking the pump out again today after collage i hope i see a leak or something.
Old May 6, 2013 | 07:17 AM
Ollie8974's Avatar
In tank leak. Check the hose clamp tightness.
Old May 6, 2013 | 09:15 AM
omarrakeen's Avatar
I hope so. am done with everything i will start digging in soon.
Old May 9, 2013 | 08:33 AM
omarrakeen's Avatar
Turned out to be an in fuel tank. it was so slight, amazing what a little drop in pressure can do. problem solved thanks
