Car will not start when hot
Old May 17, 2013 | 07:35 AM
9sectruck's Avatar
Default Car will not start when hot
MY CAR IS A PT88 5.3 STOCK LS2 CAM, 112LB INJECTORS, 60PSI BASE PRESSURE, E85. 4FT 3.5 PIPE OUT THE FRONT BUMPER.
THE CAR WILL START FINE WHEN COLD BUT ONCE YOU GET IT UP TO TEMP THE CAR WILL BACK FIRE, AND I MEAN ITS A LOAD BACK FIRE, AS SOON A IT DOES THAT IT LET OF THE KEY AND HIT IT AGAIN AND BOOM FIRES RIGHT UP 90% OF THE TIME.
i HAVE TRIED LEANING THE CRANKING FUEL TO THE POINT THE WIDEBAND WILL GO DOTS AS IT CRANKS, AND HAVE ADDED ENOUGH THAT THE WIDE BAND GOES 10.0 AND EVERYTHING IN BETWEEN.
GETTING TO THE POINT ITS KILLING MY LIL BATTERY AND HAS LEFT ME STRANDED, ANY ADVICE ON THIS E85 WHEN HOT
Old May 18, 2013 | 06:52 AM
Old Geezer's Avatar
Backfire...Out the intake or exh?
