having fuel problem need help
The will crank over alittle bit but the car willnt start. I have a fuel gauge on the fuel regulator. The gauge doesn't move at all but sometimes it goes to 10 psi. I tried 2 different fuel pumps because I thought the 1 fuel pump was dirty but I tried both pumps but the pumps turn on but it seems like its not getting pressure to the injectors. Whats the problem?
You have the return side of the rails "open"..
As it's plumbed, you have no pressure regulation.
Where did you plumb the return side of the reg to? What kind of reg is it?
In short:
Tank> 60-100 micron filter> pump> 10 micron filter> one side of rail> rail crossover to 2nd rail> out on 2nd rail> inlet on reg> regulator out to the tank.
