Need Injector help
Old Jul 2, 2013 | 09:42 PM
jetboat's Avatar
Default Need Injector help
I need help I am looking to buy new injectors 36# +or- I bout 8 trick flows part #89036 from summit part# TFS-89036 they sad they fit my engine. I have a 2003 LS III LQ9 it is newly stroked and camed the heads, intake are stock truck. I called Summit to day when my wrench sad I got wrong injectors they sad I need to buy Fast injectors 32# part FST-30332-8. I don't know if these are what I need? It should give me 425 HP at 4500 RPM for my river jet boat are 32's ok I think 2000 to 2004 truck injectors not that hard?
Thanks Kerch
Old Jul 2, 2013 | 09:46 PM
ZL1Killa's Avatar
contact Fuel Injector Connection, they are a sponsor on here.
Wrong injectors meaning they don't fit or just aren't enough?
the Fast injectors you listed are LS2 type injectors, shorties I believe. We need more details to find out exactly what injectors you need.
those trick flow injectors from summit are fatties, EV1 connector type and I think are 60mm tall? What is not working, the fuel injector fitment or the connector fitment.
DETAILS please.
Old Jul 2, 2013 | 10:28 PM
jetboat's Avatar
The trick flow's are to tall and wrong plug I don't know about the fast ones Summit sad the fast's are for LS II I sad I have a LS III LQ9 he sad they will work. I have my douts
Old Jul 7, 2013 | 01:39 PM
ZL1Killa's Avatar
there is a thread in here that tells the injector type, size, connector type...i'll have to find it.
Old Jul 9, 2013 | 07:11 AM
LS1MCSS's Avatar
So do you have an LS3 or an LQ9? They aren't the same and the intake isn't the same.
Old Jul 15, 2013 | 11:56 PM
jetboat's Avatar
I have a LQ9 and I thought it LS1 III Gen I have spent the $ for some Thanks
