fuel pressure to much or doesn't matter
Your injectors are probably rated 60lb at 3-bar (43.5 psi) meaning you are flowing ~73lb at 4-bar(58psi). The extra pressure causes them to flow more but as long as you have the correct data entered into the IFR table (based on your fuel pressure) and you re-tune your VE everything will work out fine.
