Fuel pump info
Old Jul 23, 2013 | 10:16 PM
DisasterpeaceWS6's Avatar
Cool Fuel pump info
Soon to be bolting on a Procharger. I know that I have to upgrade the fuel system. Thinking some 42lb injectors but what pump to use? What pump do you use for your blower set up?
Old Jul 24, 2013 | 08:56 PM
Good forced induction fuel pump anybody?
Old Jul 25, 2013 | 10:15 PM
drillslim's Avatar
just passing on a little info. don't know how much hp you plan on making. but u need to ck out your fuel system close. have a c5 vette. with f1-c procharger. have 60 lbs. having some fuel problems. having to go to 95 lb inj. car making around 800 hp at flywheel. so choose your fuel system with a lot of research
Old Jul 26, 2013 | 02:04 AM
Im running stock LS1 injectors now and im pulling 440 at the tires. Bolting on a procharger in a couple weeks and I plan to go with some 42lb injectors and a racetronix fuel pump and booster. After the install i should be some where in the neighborhood of 550-600rwhp.
Old Jul 26, 2013 | 02:05 AM
Just looking for some advice so that i dont go too big or too little.
