Fuel pressure problem.. stumble at accelaration
Old Jul 24, 2013 | 11:29 PM
formula88's Avatar
Default Fuel pressure problem.. stumble at accelaration
I have a 1999 formula that is pretty much stock. I use it for my everyday driver. It idles fine and revs fine. But when I try to accelerate past half throttle it stumbles, hesitates and breaks up pretty bad. I Figured it was fuel related and did a pressure test. This is where I start to scratch my head. With the key forward the gauge only reads 10 psi. But when I turn the engine on the pressure shoots to 60 psi. This has got to be the regulator. My question though, is the regulator part of the fuel pump or a separate part in the tank? Any help would be greatly appreciated.
Old Jul 25, 2013 | 03:34 AM
Ollie8974's Avatar
The fuel pressure regulator is mounted in the fuel pump module. However it is easley removed, by pushing the retainer up.
Attached Thumbnails Fuel pressure problem.. stumble at accelaration-img_1009croped.jpg   Fuel pressure problem.. stumble at accelaration-img_1010croped.jpg
Old Jul 25, 2013 | 11:19 AM
KENS WS6's Avatar
It is located on your fuel rail not your pump. Its on the drivers side rail.
Old Jul 25, 2013 | 10:31 PM
formula88's Avatar
Thanks ollie, I think I'll take care of it over the weekend. question is should I just replace the regulator or swap the regulator and pump? The car is close to 140k now. I don't even hear the pump whine anymore when the key is turned forward.
Old Jul 26, 2013 | 05:20 AM
Ollie8974's Avatar
1999 - 2002
The fuel pressure regulator is in the fuel pump as shown.
Old Jul 26, 2013 | 05:25 AM
Ollie8974's Avatar
With 140K miles, as long as the pump module is removed replace both the pump and regulator.
Old Jun 29, 2014 | 09:52 AM
hwarb's Avatar
Where is the regulator on a LT1 ?
