fuel pressure question
Old Aug 10, 2013 | 04:35 PM
jt_2002_ta's Avatar
Default fuel pressure question
what is the norm for pressure on a 01 ls1 stock fuel system? when i hooked the gauge up and turned key on it was around 30. with it running it was 55-58 and under load dropped to 50 or so. is this a issue with my mods? should it hold steady under load?
Old Aug 10, 2013 | 04:46 PM
HCI2000SS's Avatar
Ideally it should hold steady, but a 5-8 psi should be okay. Mine drops about that much, and I have a built HCI LQ9 with a 100 shot to boot
Old Aug 10, 2013 | 04:54 PM
jt_2002_ta's Avatar
could it maybe be a sign that injectors are maxed and not able to get the fuel it needs?
Old Aug 10, 2013 | 05:18 PM
HCI2000SS's Avatar
Well maybe, but in my case for example I have 42 lb injectors, so the drop is coming from somewhere else for me
Old Aug 10, 2013 | 05:53 PM
35th SS's Avatar
stock should be in that area 58psi give or take.340 walbro intank here 60-62psi. here.stocker might be goin out.
