Injector question
I have a line on some stock ones which are 28.8 lb or some 36lb ones. I am new to fuel injection so I dont know which is better. The motor is in what I consider to be a cruiser so basically keeping her stock, just may slide a slightly larger cam in there.
Thoughts?
I don't know what exactly your entire setup is and what is and isn't stock or aftermarket that you have done, but I suggest if you are changing things from stock that you find someone or a mail in tuner and get HPTuners or EFI Live and get things tuned.
If you continue to modify, such as changing intake, exhaust, cam. You will need a tune, and if you do things all separate you will need a tune-up each time. An intake isn't so much of a change, so the fuel trims and take care of that usually. I don' t know what the factory injectors are on the lq4 but I bet they are not 36# injectors, so it would need a tune for that.
DO not run the vehicle on anything other than stock injectors until it is tuned for the other injectors.
the only "performance" mod I am doing at this time would be headers...
I am new to this entire FI thing so thanks in advance.
