How do you scale larger injectors?
Old May 3, 2004 | 08:35 PM
whitt1's Avatar
Default How do you scale larger injectors?
I'm installing a new engine combo in my truck and need to install larger injectors.Is there a formula for scaling the injectors with edit?
Old May 3, 2004 | 09:08 PM
felton316's Avatar
New injector size divided by old injector size * 100 gives you the percentage to multiply by in LS1 edit. ex 42#/28#= 1.5 * 100= 150% Scale the IFR table by 150% to get 42's to run where 28's were. That should get you close enough to get it running then fine tune it with some logging.
