fuel gauge issue
Old Sep 21, 2013 | 11:36 AM
Possum Boggs's Avatar
Default fuel gauge issue
my fuel gauge goes crazy sometimes and dops below empty and makes the check gauges light come on,and then most of the time it works fine,i had it code scanned and it said it was a fuel sensor,where is it located and is it hard to change?
Old Sep 21, 2013 | 03:58 PM
Ollie8974's Avatar
The sensor it self is not hard to change. How ever it is mounted on the fuel pump module in the tank. requires dropping the tank.
Attached Thumbnails fuel gauge issue-img_1115croped.jpg   fuel gauge issue-img_1118croped.jpg
Old Sep 21, 2013 | 04:04 PM
thanks alot.so do you think thats my issue for sure,just my luck it couldnt have been a simple fuse
Old Sep 21, 2013 | 05:34 PM
man-o-war's Avatar
Unfortunately its a messy affair. No smoking while working on the tank
Old Sep 22, 2013 | 06:08 AM
Ollie8974's Avatar
I would check grounds first.
Old Sep 22, 2013 | 09:16 AM
i will go over it and check the grounds,maybe thats why it works sometimes
