new regulator installed *pics*
Old May 4, 2004 | 08:17 AM
koolrayz's Avatar
Default new regulator installed *pics*
hopefully this was my fuel problem. Cant check it till i get the rearend back in. aeromotive#13109
http://cofba.org/users/koolrayz/2004_0503_115537AA.JPG
http://cofba.org/users/koolrayz/2004_0503_115648AA.JPG
http://cofba.org/users/koolrayz/2004_0503_115838AA.JPG
Old May 4, 2004 | 11:03 PM
plumbr's Avatar
Nice plumbin...
You might want to check those compression fittings once in a while. They can work loose with vibration.
Old May 6, 2004 | 09:36 AM
Blackbird's Avatar
I think thats is teflon paste I see there and not tape.
If so get ready for it to leak. At least for me paste would not do the trick, tape works like a charm.
Just a heads up to a possible issue.
Old May 6, 2004 | 03:42 PM
koolrayz's Avatar
Well im a journeyman pipefitter that worked in oil and chemical refineries for almost 20 years and IMHO an industrial quality paste is 10 times better than tape.
Old May 6, 2004 | 04:23 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default Fuel pressure
Did that Fuel pressure reg work for you? I have the same issue?
Old May 6, 2004 | 05:23 PM
Blackbird's Avatar
hmmm interesting. you could very well be right. I just know for me it would never seal with paste. sealed right up with tape.
Old May 13, 2004 | 07:05 PM
AgentOrange's Avatar
did you let it set?? or just pressurize it right away?
Old May 14, 2004 | 12:21 PM
Nasty N8's Avatar
Paste is way better I have never had a problem. I use it on all fuel stuff.
Nate
Old May 14, 2004 | 03:13 PM
Zero2Sixty's Avatar
Paste here as well....
Old May 14, 2004 | 03:21 PM
Blackbird's Avatar
well I guess I never let it dry long enough. how long does it take to set?
Old May 14, 2004 | 06:01 PM
koolrayz's Avatar
Try a different brand. I use the loctite 567 part #56747. It's not a hard setting type and has superior sealing properties IMHO
Old May 15, 2004 | 10:13 AM
Zero2Sixty's Avatar
ARP here, remains a paste however states that it resists fuel and oils etc....
