Double Pumper Install
Old Oct 13, 2013 | 01:28 PM
maroonls1z's Avatar
Default Double Pumper Install
I am going to install my double pumper kit from lonnies here in a few weeks on the 2000 camaro and i am just trying to make sure i have everything ready to go. Does anyone have any pictures of them running the hot wire kit?. i know it is suppose to be apparent and i know you follow the original wires from the pump and cross over around the transmission and attach to the battery but pictures always help. Also since this is a N/A application I plan on using a NOS WOT/RPM Activated Window Switch
http://www.jegs.com/p/NOS/NOS-WOT-RP...62786/10002/-1
to activate the second pump. Do i also need to install some kind of pressure safety switch?
i read somewhere that someone installed a rocker to change which pump is primary so that both get equal time. Can you just use a standard DPDT change over rocker switch?
didnt want to bother lonnie with this but i will if i have to
Old Oct 13, 2013 | 07:54 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
There are 2 jumpers in my harness under the hood that control each pump.
One has a jumper & the other will activate with your window switch.
Just swap the 2 connections periodically to keep runtime equal. I recommend swapping at each oil change. No need to use any additional switches.
Also be sure the window switch is LS1 compatible. The one you stated should be fine.
If you have questions, just call me. I'll help you get your system configured properly.
Old Oct 13, 2013 | 08:40 PM
maroonls1z's Avatar
sounds great and thanks for the info, just didnt want to bother you with questions if i didnt have to
Old Oct 16, 2013 | 04:28 PM
didntdoit1171's Avatar
great info
