04 Corvette LS1 Fuel Line Question
I am trying to find a AN adapter that will let me connect to the stock Corvette single braided line that comes off fuel rail, it is a female OEM quick connect. I will be running a single stainless hardline from a Custom Vapor Works tank & I am having no luck finding a AN adapter fitting for it ? Also will 3/8" -6 line be adequate enough for the stock LS1 motor ?
Thanks Perk
Thanks Perk
No that is not what I need, Here are a few pics of the Corvette OEM line I am trying to adapt to. It is Female both ends, So I would need the OEM male On end that goes into the braided line & a AN end to adapt to either stainless hard line or braided stainless line.
Perk
Perk
Give this one a shot: Russel 640940
http://www.summitracing.com/parts/rus-640940/overview/
Use a tube nut/flare on the stainless line if it doesnt have a threaded fitting already. Yes, a single 3/8" line is more than enough for a LS1, even heavily modded
