Problems
Old Nov 19, 2013 | 04:52 PM
1quickz's Avatar
Default Problems
my 93 z28 wouldn't turn over after removing the plugs the third cylinder on the passenger side was filled with gas. i removed all the injectors cleaned and replaced all the o rings, and put it all back and went to fire it up and it ran for a second i shut it off went back out to the car tried to start it and once again it wont turn over and it acts like if filled the cylinder up again, any ideas on what this could be?
__________________
Old Nov 19, 2013 | 05:33 PM
Old Geezer's Avatar
Changing the externals won't cure a stuck inj issue.
Continue this, and you'll be jacking the rods thru the block...
Have the injs tested, check the harness for shorts.
Old Nov 26, 2013 | 08:51 PM
johnson73801's Avatar
if it were me id put on a pressure gauge and unplug the injectors and pressure up... if pressure still drops its mechanical if it only does it plugged in something is shorted and opening injector.
Old Nov 26, 2013 | 11:38 PM
Blown06's Avatar
8 Second Truck Club
yea your gonna hydraulic the thing if you keep trying it. You obviously have an injector stuck open or something going on.
If you don't know what "hydraulic" the motor means..........its very bad.
