Limit of stock '01 injectors
Old May 7, 2004 | 10:06 PM
98_1LE's Avatar
Default Limit of stock '01 injectors
I just had a 347 built with PP LS6 sytle heads, 231/237 cam, and the car has all the boltons. It will never see nitrous or forced induction. Should I upgrade to SVO 30# injectors?
Old May 8, 2004 | 06:24 AM
PREDATOR-Z's Avatar
Nope, but I would do a fuel pump.
Old May 12, 2004 | 06:35 AM
mr. Jones's Avatar
yes, put in the 30lb svo injectors.
your duty cycle will by close to 100% with the stock
injectors. spray pattern and injector life sufer.
Old May 13, 2004 | 01:26 AM
U LUZ's Avatar
the injectors you have are good to 572fwhp at 100% duty cycle and 458fwhp at 80% .....30lb injectors are good for 692fwhp at 100% and 554 fwhp at 80% you make the call......you are going to be running at about 92-95% at wot depending on the power you make ive seen that setup make 460 at the wheels with all the bolt-ons.... elec.waterpump,no belt, etc.
Old May 13, 2004 | 01:28 AM
U LUZ's Avatar
do a fuel pump and 30 lb. injectors and you will be fine....
Old May 14, 2004 | 12:23 PM
Nasty N8's Avatar
Do a Walbro and you should be fine.
Nate
