Turbo guys...Fuel question!
Old May 10, 2004 | 02:16 AM
DarkblueTA's Avatar
Default Turbo guys...Fuel question!
I have the P1SC listed in my sig. I am going to do a 71mm Turbo swap though. I currently have 38# injectors, the ATI inline fuel pump and intake stock pump. I am going to run 8-10# of boost(maybe 12 eventually) but I was wonderin if everything but the injectors will be fine.
I know I'll have to up the injector size and I was wondering if 50# injectors would be enough or if I'm going to have to get a low impedence injectors and the conversion box.
Any help would be gratefull. Thanks in advance!
Old May 10, 2004 | 05:54 AM
smokinHawk's Avatar
id go no smaller then svo 42's or seimans 55 or motrons 60's
you can get a high impedance injector so you do have to have a conveter box to save you money.
Old May 10, 2004 | 10:47 AM
DarkblueTA's Avatar
The SVO 42s will act like a 55/60# GM injector...correct? because of the difference in fuel pressure between the 2 fuel systems?(Ford running at 43 or so and GM running 58 or so)
