What fuel system for 650rwhp
Old May 10, 2004 | 09:42 AM
Phil99vette's Avatar
7 Second Club
Default What fuel system for 650rwhp
99 Corvette, all the bolt-ons. What type of fuel system do I need? I already have a big fuel pump.....
Phillip
Old May 10, 2004 | 10:37 AM
onfire's Avatar
Coal Mining Director
I would do a Racetronic plug n play set-up. 340 walbro in the tank (already in ?), Hot wire kit to keep voltage drop to a minimum, MSD boost-a-pump set at 15 volts and a 1997 vette fuel rail complete with factory regulator and a factory return line.
Old May 10, 2004 | 11:28 PM
Slowhawk's Avatar
LS1Tech Sponsor
Contact Nate at Nasty performance,he will hook you up with all parts needed.
I did a new -8 feed line,rails,regulater,340l walbro,and used the stock feed as the return.Solved all pressure drop problems with the 600+rwhp car we have it on.The stock feed system would start at 60psi and drop to 50psi by 6200rpm.Now it starts at 53psi and goes to 68 psi at 6800rpm.(boost regulator)(no voltage booster)
