Help)+=
Old May 10, 2004 | 01:31 PM
n2o-99ta's Avatar
Default Help)+=
My 99 M6 TA has been acting up for the last few months. Whenever the car is in gear and I try to accelarate it jerks real bad and then stalls with a loud backfire. I thought the intake manifold might be leaking so I picked up a used stock one and put it on. At first I thought that this helped a little. It drove the car for about 20 miles and it seemed to get better the longer I drove it. In fact the car was running almost perfect when I noticed how low on gas I was, so I filled her up. And now the problem is worse then ever!?! I almost didn't make it home)-= Why would the amount of gas in the tank make a difference? Any help or ideas would be greatly appericeted.
Old May 11, 2004 | 11:56 AM
technical's Avatar
Normally it shouldn't. It *sounds* like you're running really rich. Does it buck real hard before it pops? Kinda like a bad surging feeling?
Any mods that might affect this? Something that would push that much fuel into the engine? Are you using a wet NOS system?
