Removing the Vapor return line?
Old May 10, 2004 | 07:41 PM
Mike94ZLT1's Avatar
Default Removing the Vapor return line?
I dont like it. I want it gone. Those 2 lines on the drivers side that run to my intake. One is for fuel, and apparently the other one is for emissions? Can I remove it? I have no AIR or EGR, what needs to be disabled? Thanks!
Old May 10, 2004 | 11:35 PM
HOTROD98Z's Avatar
Just remove the one end from the intake and the other end from the hard line and put vacuum caps over both spots.
Old May 11, 2004 | 12:55 AM
Mike94ZLT1's Avatar
That wont cause any problems or SES lights? If so then its GONE! Thanks!
Old May 11, 2004 | 03:42 PM
HOTROD98Z's Avatar
No it won't cause any problems, as far as setting a SES light i don't know if it will or not.
Old May 11, 2004 | 04:48 PM
theblur98ss's Avatar
I think it will set a code. purge evac solenoid or something like that. I just ripped all that garbage off and programmed it out. Make the engine bay look alot neater.
Old May 11, 2004 | 06:21 PM
BattyV6's Avatar
I want to do the same thing...what else can I take out? The soft line under the hood, the hard line under the car...what else? thanks
Andrew
Old May 11, 2004 | 08:31 PM
Zero2Sixty's Avatar
Any downside to doing this ? Im ready to yank that sh*t off right now before I reassemble everything. Should the evap be deleted 1st or will it hurt to remove it then have the local speedshop edit it out ?
Old May 11, 2004 | 08:39 PM
needmoremoney's Avatar
Where do you start to remove it from. When installing the LSx intake, there isn't even a spot now for it, so I would like to remove it to, just dont know where to put a vacumm cap...
Old May 11, 2004 | 11:51 PM
HOTROD98Z's Avatar
No their is no downside to doing this and it's fine if you pull it out first and then have the code deleted if it does set one. The evap line is right next to the feed line, just pull the evap line off where it connects to the hard line and cap the hard line off with a vacuum cap and since the LSX doesn't have a hook up for it, that's all you have to do.
Old May 12, 2004 | 12:09 AM
BattyV6's Avatar
Has anyone removed the hard line as well? I am just about to re-install the fuel lines and 1 would be easier than 2 to put back in...thanks.
Andrew
Old May 12, 2004 | 10:45 AM
BattyV6's Avatar
Just to get things straight...you guys are talking about the two rubber lines that are wrapped in the silver heat tape???
Andrew
Old May 12, 2004 | 10:52 AM
Kevin 276's Avatar
Andrew
The two lines,hoses what ever you want to call them that are running along the driver side strut are airpump and hood latch cable, nothing to do with fuel line. Yes, you can remove the large one and reroute the hood latch cable underneath the wheel well out of sight.
The two rubber hoses wrapped in silver heat tape connecting to the fuel rail are obviously fuel lines. You obviously can't remove those...
Old May 12, 2004 | 12:28 PM
Zero2Sixty's Avatar
Cool, last question - what size fuel disconnect did you use, or better yet how did you remove it. My 3/8 fuel disconnect doesnt seem to release it. Perhaps Im not being persuasive enough
For clarification, the LSX does have provisions for the evap. What they no longer provide is a 'mounting bracket' for the evap.
Old May 12, 2004 | 12:38 PM
SapphireHawk's Avatar
You do use a 3/8 inch fuel disconnect tool. It does take some defenite persuasion. Make life easier on yourself and get the metal one if you have the plastic one.
Old May 12, 2004 | 12:45 PM
Zero2Sixty's Avatar
Yes, I used the plastic disconnect - I'll pick up a metal one tonight.
Old May 13, 2004 | 01:32 PM
Zero2Sixty's Avatar
Once the line and intake are capped, how does the vapor line vent ? Or does it ?
Old May 13, 2004 | 02:28 PM
smokinHawk's Avatar
if you cap it you wont be able to fill up your gas tank when empty. been there dont that, you need a vent valve.
i got rid of everything to the tank (cept i left the line on should remove that sometime.)
smokinHawk's Avatar
http://www.cofba.org/users/smokinhaw...-pics/fuel.htm
Old May 13, 2004 | 02:52 PM
Zero2Sixty's Avatar
well damn, there's got to be an alternative way than going through all that...
Old May 13, 2004 | 05:01 PM
MIGHTYMOUSE's Avatar
if you cap it off you will have fill problems, i removed everything including the line under car, and just let it vent out of the soft line going to the top of the tank
