Fuel Pressue slow drop over time - is this acceptable?
Old Feb 12, 2014 | 07:20 AM
Kody95cam's Avatar
Default Fuel Pressue slow drop over time - is this acceptable?
With key on, no engine running, I have pressure consistently at 41. 2995 Camaro 5.7 LT1. However, the system is slowly leaking somewhere. I have already found and replaced two injectors that were leaking fuel slowly. Here are the time stamps and corresponding pressures after no more injectors are visibly leaking: 9:50 pm 41. 10:04 38. 10:18 37. 10:35 35. 11:00 pm 33 went to bed. Checked it at 7 am this morning and pressure is all the way down to 11 now. Is it physically possible for an injector to leak air and not fuel? Are these pressure drops within acceptable ranges or do I need to keep looking for more leaks? I was getting gas in my oil which is why I am testing in the first place. Thanks!
Old Feb 12, 2014 | 08:46 AM
ss performance's Avatar
I would keep looking for leaks. I have no idea what would be an acceptable pressure drop. Could be in the regulator or fuel pump.
Good Luck
Old Feb 12, 2014 | 11:00 AM
Old Geezer's Avatar
That is OK. The pump check valve is likely where the drop is coming from.
[Assuming no inj leaks]
Old Feb 12, 2014 | 11:08 AM
KENS WS6's Avatar
That happened to me last year. Check the wire under the gas tank. mine was loose and it would do the same as what you are going threw. It should be at 58psi
