Suggestions on Venting a Race Fuel Cell?
Old May 24, 2004 | 07:47 AM
FEAR THE LS1's Avatar
Default Suggestions on Venting a Race Fuel Cell?
Here is an easy question for some of you fuel experts.. I am installing a custom fuel system for my new motor. I installed a 3 gallon sheet metal fuel cell, it has 2 10AN feed lines on bottom and 2 6an return lines on top. Any recommendations on using one of the return fittings as a vent? I don't want to create a vacuum in the tank right? I will need to vent it out?
Thanks,
Lee
Old May 24, 2004 | 09:06 AM
technical's Avatar
Thanks,
Lee
You're using one of those return fittings for a return line, yes?
I've only seen imploded tanks from malfunctioning evap systems. I don't believe a fuel pump will create vacuum. On the other hand, the cell will need some sort of vent since gas vapors like to expand with heat. You'll need a check valve or some type of one way valve in case ( god forbid ) you end up side down.
Old May 24, 2004 | 09:17 AM
Yes I am using one of the #6 fittings on top of the tank as a return. The tank has 2 feed fittings on bottom and 2 return fittings on top.
Do you or anyone else recommend a particular part# for this application?
Here is one item I found so far:
JAZ Roll Over Vent Valve
JAZ roll over vent valve allows air to replace the diminishing fuel level and it acts as a check valve to prevent fuel from spilling out of the cell in case your vehicle is ever upside down.
#547-834-006-11 -06AN Roll Over Vent Valve
Old May 24, 2004 | 09:23 AM
technical's Avatar
Sounds like that JAZ unit is what you're looking for. There might be a similar unit from the same company that manufactures your fuel cell.
