New here! fuel help
Old Feb 12, 2015 | 03:21 PM
dannyc10's Avatar
Default New here! fuel help
I have a bagged c10. Just installed the 01 lsx. I have a 25 gal. From a blazer I'm going to put out back. What pump can I run in this tank? Also I'm going to run all new lines. Braided lines for 100psi? I have a external vette pump but I'm thinking now of running in tank. Thanks!
Old Feb 12, 2015 | 09:15 PM
76larkman's Avatar
if the blazer pump has correct pressure rating I would run that. You can run fuel injection hose and have place that makes hoses press correct ends on or go A-N fittings. I modifyied a new tank for my skylark to use a factory 06 silverado pump assembly with no problem. I sumped the bottom of tank for pump to be in. In tank pump is quieter.
