Using a -6an where a -6an orb is needed?
Old Mar 29, 2015 | 05:22 PM
johnminer's Avatar
Default Using a -6an where a -6an orb is needed?
I want to use the 3/8" to 6an fitting to go directly from my stock fuel rail to the the aeromotive 13129 FPR. The FBR says to use -6a/n o-ring fittings. Will the 6a/n non o-ring fittings leak? Can you just add a o-ring to the -6a/n fitting? I haven't used an fitting before, so i'm not sure if that will work.
http://www.summitracing.com/parts/ru...wjYaAlry8P8HAQ
http://www.summitracing.com/parts/aei-13129
If that doesn't work I can add a -6an to -6an o-ring fitting and a -6an female to -6an female fitting. I just don't want to spend another $60 on fuel fittings if I don't have to.
http://store.custombuiltmotors.com/e...b-fitting.html
http://store.custombuiltmotors.com/e...n-fitting.html
Any help or input is appreciated!
Old Mar 29, 2015 | 06:02 PM
.boB's Avatar
You have to use the specified ORB fitting, or it will leak like mad.
Old Mar 29, 2015 | 08:39 PM
johnminer's Avatar
Okay. Is it just because regular 6an doesn't have an o-ring or is it because the end is protruded? The thread looks the same minus the lack of o-ring and protruded end. Can you cut the end off and add an oring? Thanks!
http://www.improvedracing.com/an-ada...ing-p-151.html
Old Mar 29, 2015 | 10:19 PM
.boB's Avatar
The fitting is different on each end. The threads are the same on each end, IIRC. But the O-ring end threads are much closer to the hex portion, so you can tighten it down onto the O-ring. If you cut the end off of a standard fitting, you won't be able to tighten it down enough to effect the seal. And It might extend into the regulator too far.
Spend the few bux and get the right fitting for the job.
Old Mar 30, 2015 | 01:53 PM
John at CBM's Avatar
Arrow orb and adapter
Hi,
CBM MOTORSPORTS
LS style fuel rail adapter.
CBM MOTORSPORTS
-6AN to -6AN ORB fitting.
$32.00 for both.
Thanks
Old Apr 2, 2015 | 04:19 PM
johnminer's Avatar
I went ahead and bought the right fittings. Thanks!
Old Apr 2, 2015 | 04:27 PM
johnminer's Avatar
Originally Posted by John at CBM
Thanks for the reply! It would be cool if you offered a 3/8 fuel adapter to 6an orb fitting. I don't know how many you'd sell, but it would have saved me from buying two other connectors.
