What could cause.....
Old May 9, 2015 | 11:51 AM
Orange Juice's Avatar
Default What could cause.....
2001 Camaro with a racetronix 255 pump kit. For some time the fuel pressure would bleed off in a couple of hours but come right back up when the ignition was turned on. Also on the dyno th fuel pressure dropping off at 5000 plus rpm. I purchased a new fpr and had it installed. That only seemed to make the car worse. Car is very hard to start and now there is no fuel pressure/fuel pump by turning on the ignition. The car will run by cranking the motor over. I have bought a new fuel pump and the tank is coming down again tomorrow to put in the new fuel pump.
