Single walbro 450 limits
Old Feb 22, 2016 | 12:03 PM
gnx7's Avatar
I run (2) Walbro 450lph pumps which supports 1400hp flywheel on e85.
Overbuild your fuel system... or suffer a motor meltdown doing it half assed.
Old Feb 22, 2016 | 12:57 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by stage274
Your right, Racetronics hooked me up, also, I got the twin 340s, as far as the Boost of pump, it does not work on the bigger pumps. 340 and above, because they pull to much amps.
The larger KB BAP can supply up to 40 amps of current!
Our RXP340 pumps draw apx. 17 amps each @ 16V @ 80PSI.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Feb 22, 2016 | 01:16 PM
Atomic's Avatar
I need a gauge for that
This is what my math says...for 2 pumps basically double the power number. You would want to use your base fuel pressure + boost pressure (if using a referenced regulator) as the pump pressure on the bottom. Read up then over to the left. A voltage booster would shift both lines upward.
Example, 55psi base pressure and 20psi of boost on gas. Enter bottom at 75psi to the red line, then over to the left for just shy of 800rwhp.
