Fuel pressure relay pops?
Old May 26, 2015 | 09:49 AM
2000Hawk#317's Avatar
Default Fuel pressure relay pops?
I have an LS1. I'm having an issue with my fuel pump staying on. I can turn the key on and the fuel pressure will go to 10 psi then I will hear the relay pop. I have extra relays so I know it's not the three that I have. Why do I keep hearing this? And does anybody have a fix?
Old May 29, 2015 | 11:32 AM
Project GatTagO's Avatar
When you turn the key to the RUN position, the ECU turns on the fuel pump for 5 seconds to prime, then it shuts off until the engine starts.
Andrew
