what fuel rails and injectors to run??
Old Jun 6, 2015 | 04:02 PM
acechevy's Avatar
Exclamation what fuel rails and injectors to run??
I have a 98 camaro i know the fuel system is different from other f bodys .. Im installing the 6,0 with l92 and ls3 intake in my 98 camaro cant find anything on the swap and what injectors and or rails would make this swap right.. aftermarket or factory either way doesnt matter.. Also whats a good fuel pump that everyone recomends? Thanks ace
Old Jun 6, 2015 | 06:58 PM
Mexyenne's Avatar
Hello,
For a 450hp engine, assuming 85% duty-cycle and a BSFC of 55 a set of 37 lb/hr or 383 cc/min injectors will be enough. Now, for the same power level and BSFC the app says a minimum of 156 LPH pump would be required.
Cheers!
Old Jun 7, 2015 | 12:46 PM
one fast zo6's Avatar
stock ls3 rails and injectors. If over 600wp than stock zr1 ls9 injectors.
that is the cheapest and best way to go.
Old Jun 7, 2015 | 12:48 PM
single 340lph pump
Old Jun 7, 2015 | 08:33 PM
Mexyenne's Avatar
Default Correction for 600 HP
Well, adjusting the HP slider up to 600hp the app gives an injector flow of 61 lb/hr (stock ZR1 LS9 are 56 lb/hr) and a pump of 265 LPH. Double check as the pump flow comes below the one suggested by "one fast zo6".
Old Jun 9, 2015 | 05:01 PM
eaglegoat's Avatar
Ls9 injectors are 52.5lb/hr@4bar.
Old Aug 4, 2015 | 04:00 PM
acechevy's Avatar
So the stock ls3 rails and injectors will work with the fuel lines and pump set up that the car has in it factory? With a pump upgrade? Motor is looking to be around 520 to 540 at flywheel from estimating
Old Aug 4, 2015 | 04:09 PM
acechevy's Avatar
What size throttle body fits the ls3 intake 92 or 102
Old Aug 6, 2015 | 11:17 PM
eaglegoat's Avatar
Both will fit. But the manifold opening is 92.
Old Aug 11, 2015 | 11:04 PM
acechevy's Avatar
Ok thank you.. trying to figure out the regulator set up ls1 is on the rail iif I'm thinking right and ls3 is in the tank
