Fuel pump and fuel system ???'s
Old Jul 24, 2015 | 03:52 PM
DieselDriver's Avatar
Default Fuel pump and fuel system ???'s
I'm in the process of setting up my fuel pump system, and have a few ???'s
Donor engine 2002 LQ9 from a Escalade w/ a feed and return line
Recipients Vehicle 1991 Toyota Land Cruiser
The LC is fuel injected, I see three options for me...
1 stock 1991 pump About 45/50 psi
2 stock twin turbo supra pump about 50/55 psi
3 fit the correct GM pump
I see the LQ9 wants 60psi, if I use the stock GM pump do I need to use an additional regulator?
I have read my builds where they use the TT supra pump and they run fine
Can anyone give me do's and dont's before I buy a pump
Old Jul 25, 2015 | 07:58 AM
eaglegoat's Avatar
Regardless run a regulator. GM base fuel pressure is 58psi. What are you using for engine management?
Old Jul 25, 2015 | 03:04 PM
In regards to the regulator, there is one the fuel rail. Is this enough?
I am using the stock ECM w/ hp tuner
Old Jul 25, 2015 | 07:42 PM
eaglegoat's Avatar
Huh?
If you're saying there is one then just verify your pressure is @58psi.
Old Jul 26, 2015 | 08:29 AM
Yes, I thought that's what it was from the factory?
It's a round cap w/ vacuum line, it's located in the fuel rail, two fuel lines are present at the intake manifold
Old Oct 18, 2015 | 03:47 PM
Adam Brockwell's Avatar
I don't think that's your return line, that goes to your emissions canister. You should have a bleeder valve on the fuel rail itself where you can test pressure. I have a 2004 lq9 and as far as I know there is no regulator?
