Building a Holley EFI Dominator setup!
Holley parts list:
Dominator EFI ECU #554-114
LS2 Main Harness #558-103
LSx Injector Harness - For EV6 Style Injectors #558-201
GM 4L60/80E Transmission Harness #558-405
If anyone has any vendors that can do a better price than the Holley site, I'm interested as well. I have an email sent to Martin at Tick so i should hear back from him in the next day or so.
Also, if anyone has suggests on good vendors for fuel lines & fittings, I'm interested to hear those as well.
I appreciate your time and any help given!
Which is it, DBC or DBW that U R going to use?
Different harness requirements...
Holley parts list:
You will need the components as you listed:
Other components you will need:
Main Power Harness #558-308.
If you run the DBW, you will need the J3 harness.
A Wideband: Either Bosch or NTK #554-100.
A MAP sensor depending how much boost. Probably 3-bar: #554-107.
(2) Boost Control Solenoids: #557-200.
Pressure transducers: Depending what you want to datalog or have for other gauges. 100PSI Sensor: #554-102. I use Fuel Pressure, Oil Pressure, and Dome Pressure.
You could run cheaper components listed above for the MAP sensor, solenoids, and pressure transducers. Some people have luck running non-Holley stuff and others don't.
You also need to get an idea of how many inputs and outputs you will have. This will get you an idea of what you need for harness for these.
The J1A/B harness has 4 inputs and 4 outputs. #558-400.
If you need more, you will need J2A (inputs) and J2B (output) harnesses. If you only have a couple of additional inputs or outputs, I would highly recommend just buying the components and building you own harnesses. These harnesses come with the plug and a bunch of random loose wires with terminals. You are paying a premium for the wires with the terminals on them. The Holley Forum website has all of the components to build your own.
This should get you a little closer.
